VRixxo
May 28, 2026Aspirant
RAX54v2 Locked to Canada
Hello, I live in a area with high interference and was doing latency sensitive task so decided to use 160MHz and DFS. Unfortunately the router I bought from Amazon is somehow region locked t...
May 28, 2026Guru - Experienced User
Is this a new purchase?
What firmware version is on it?
- VRixxoMay 28, 2026Aspirant
Ive had the router for some time but didnt need to use DFS til recently.
And I've updated the Firmware to the latest 1.0.17.144 since it fails to take any custom .CHK
- FURRYe38May 28, 2026Guru - Experienced User
And this latest version won't load on it?
https://www.netgear.com/support/product/rax54sv2
What ISP are you with?
Brand and model# of ISP Modem the router is connected too?
