Orbi
Mar 05, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if y...
michaelkenward
Jun 20, 2019Guru - Experienced User
ThisSucks wrote:
Can't use customer service because they made it impossible to reach them.
How did you try?
JJsalsa
Jun 20, 2019Guide
Here's my update to this saga we all seem to share:
Support told me that they can't replace the unit since I purchased it from a private seller. It was clearly new when I got it (shrink wrap still intact) and registered fine on the Netgear site. So, if you buy one and change your mind, and sell to a friend, they are saying that voids the warranty!
On the technical side, I down graded to the 1.0.1.56 firmware (from 58) that is the subject of this thread and it has behaved a lot *better* than 58. But still has crashed about 4 times today. Seems to do better when it's in use than when I leave it alone! Tempted to keep moving back in time... next would be 1.0.1.40. But I may just re-install my old, very stable R8500 model that works fine but has about 1/2 the throughput... Truly a bummer they would release such crap.
J
- SAM_the_GAMJun 20, 2019Luminary
I have not tried any earlier firmwares. 1.0.1.56 seems to be more stable to me then the latest 1.0.1.58.
- JJsalsaJun 21, 2019Guide
More followup since I downgraded firmware to 1.0.1.56:
Router still craps out at least 4-5 times/day and seems to do so more reliably when I'm NOT using the wireless connection - as in when I'm gone or during night.
Oddly, when I do a hard factory reset using a paper clip and reset button, it always comes back to the state it was in prior to that after boot - meaning that all my settings are still there. I was advised by Netgear and this community to do a factory reset after any firmware change and that I'd need to re-enter all my settings. So, how is it that a hard reset does not lose the previous state??
Jake
- SAM_the_GAMJun 21, 2019Luminary
Have you tried doing factory reset in the GUI? That is the only method I have tried and it works, I have not experienced any resets with 1.0.1.56 but I had plenty of resets with 1,0.1.58 especially when my Apple Watch tried to connect to the WiFi.
- JJsalsaJun 22, 2019Guide
Regarding Factory Reset: The User Manual describes using the reset button as the way to do this. along with the Erase function to erase all settings, so I have not yet tried the Erase function. But very oddly, the reset button method does not erase the settings on my unit. I hold it for at least 5 seconds as instructed.
One more oddity: I see a lot of DoS attacks reported in the log and I've read that this happens in other models too. I see no such thing in my older R8500. My new modem (ATT fiber) is set in "passthrough" mode, so it simply passes the I/P address assigned to it from the network to the Router. I'm wondering if I should instead let it assign an address to the RAX80 via DHCP or assign one manually that is on its internal network...
Otherwise, I replaced the R8500 for now since so tired of the constant power resets needed with the RAX80! Very very frustrating...
- michaelkenwardJun 22, 2019Guru - Experienced User
Netgear is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Just use whois to see who is behind some of them. You may find that they are from places like Facebook, Google, even your ISP.
Here is a useful tool for that task:
IPNetInfo: Retrieve IP Address Information from WHOIS servers
- SAM_the_GAMJun 22, 2019Luminary
1.0.1.56 seems to be the most stable for me compared to 1.0.1.58. Even though one of the bugs I experience with both firmware is that on my GIG connection through Spectrum periodically the max speed I would get over Ethernet or Wireless 5G is 500 Mbps down. I would have to reboot the router to regain full speeds.
Anyone know what is an acceptable download speed over 5G connecting at 866 Mbps? The fastest I seem to get on speed tests on my iPad Air 2019 is 640/40. I was able to get around 660/40 sometimes on 1.0.1.58 but that version is too buggy,
