Orbi
Mar 06, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
 Not even sure where to post this since my model number is RAX80.  Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23.  Or the http interface doesn't update if y...
Christian_R
Jun 24, 2019NETGEAR Employee Retired
Hello Stianu89 - Have you gotten a chance to contact our support team? Your may activate your complimentary support using the link below.
https://www.netgear.com/support/default.aspx
~Christian
JJsalsa
Jun 24, 2019Guide
RAX80: I can now report that I also downgraded my firmware to 1.0.1.40 and finally the reset function worked after that (the hard reset didn't even work properly with .56 or .58 for me). After that downgrade and re-programming the settings, the unit is FINALLY acting more stable. No reboots or crashes for a whopping 12 hours so far ;-) It still forgets all the names I put in the Attached Devices, but otherwise is working. So from my POV, .40 was the last stable release. If memory serves, the wireless speeds are not as fast as the later firmware. But it is clear that the last two releases introduced a lot of bugs and were not tested comprehensively...
- SAM_the_GAMJun 27, 2019LuminaryI finally had to downgrade to 1.0.1.40 from 1.0.1.56. Started to experience some of the bugs reported here with 1.0.1.56 after a week worth of uptime. - JJsalsaJun 27, 2019GuideI have sadly relegated my RAX-80 back to paper weight duty, after several days of stable operation with firmware 1.0.1.40 and then several days where it was crashing again about 4 times per day. It is just absurd that Netgear would release a product this unstable. When it is up, it works great, but what good is that when it goes down randomly otherwise? And having to DOWNgrade firmware 2 revisions from the current release to obtain even a modicum of stable operation is also ridiculous. This unit is unuseable as is. And either everyone on this forum thread has hardware issues, or Netgear has firmware issues. I tend to believe the latter... I'm not sure how (if) they test their products under varying setup conditions, but this unit is not ready for prime time.
