Orbi
Mar 05, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if y...
SAM_the_GAM
Jul 25, 2019Luminary
Went back to 1.0.1.56 from 1.0.1.62 due to the LAN / WAN disconnecting. However, the GUI Language version is still for 1.0.1.62.
JJsalsa
Jul 26, 2019Guide
Tryed 1.0.1.62 briefly yesterday after dusting off my thus far unstable RAX80 and it failed in numerous ways within the hour. LAN/WAN disconnect, unstable to web interface (or App). Got stuck updating device names or assigned I/P addresses. Not sure what they're doing over there but it's not progress... (The most stable release to date was .40)
- StaticLNXJul 26, 2019Star
I've got the exact same problem as JJsalsa does:
JJsalsa wrote:Tryed 1.0.1.62 briefly yesterday after dusting off my thus far unstable RAX80 and it failed in numerous ways within the hour. LAN/WAN disconnect, unstable to web interface (or App). Got stuck updating device names or assigned I/P addresses. Not sure what they're doing over there but it's not progress... (The most stable release to date was .40)
- kemcroJul 26, 2019Guide
I took my Asus RT-AX88U that was in service for 17 days without having an n issue or reboot (with two AX clients) to test this release on the RAX80 and it dintn't last an hour without random clients disconnecting and horrible internet speeds. back to my Asus AX888U and everything is stable again. Shamefull netgear, get your act together! Love my netgear cable modem but this device is garbage in its current state of hardware/firmware.
- myerswJul 27, 2019Master
+1 on cable modem. My Netgear modem runs well also.
I do not understand how Netgear can be so screwed up on the router firmware side of the house. It is obvious that they do not test for issues being fixed as there is the same issues release after release. Now they have put out firmware where tabs for managing are missing. How would this ever get by a good quality control? While others have issues, Netgear seems to be going out of their way to be the worst.
