Orbi
Mar 06, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
 Not even sure where to post this since my model number is RAX80.  Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23.  Or the http interface doesn't update if y...
michaelkenward
Aug 04, 2019Guru - Experienced User
Dazzamatazz wrote:
Just bought an RX80. Configured and it through the app. The connection lasts 2 minutes on most devices before dropping on a variety of devices. Then I get a message "password incorrect", even though it's not. Found out on this form that it has trouble with special characters. Well, that's useless then for a password!
I can think of vqarious things that mighyt cause that.
Did you just come here to complain about Netgear? Or do you want help? If so, you'd be better off starting a new discussion.
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you want help with your problem, check all previous stuff that may be related. Then start your own discussion. In this was you can also provide the information that the forum suggests that you provide.
If you do decide to ask a question, you really need to provide more details. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
JJsalsa
Aug 04, 2019Guide
Dear Michael,
Your suggestions to start a new thread or ask specific questions are good, but beating up on people that are very frustrated with this product is not any more productive than what you complain about the complainers doing! The guy buys a brand new router and immediately has disconnect problems that are well documented elsewhere in the forum too. So, is he crazy? Or does he have a valid complaing.
It is no secret that forums often contain content from people complaining who do not understand how to use the equipment they criticize. But it is their right to post as much as anyone elses.
In my opinion, the RAX80 potentially has both hardware and firmware issues. I have complained a lot on this thread because I came from using a perfectly functional R8500, setting up the RAX80 as close as possible to that, and it is utterly unstable. I have 30 years experience using computers and a Ph.D. in Electrical Engineering. I really don't believe it is my fault that the RAX behaves this way. Add to that Netgear telling me to get lost because I bought it from a private individual (in original box, shrink wrap). That adds up to a lot of frustration. I've tried four different firmware releases and none of them even approach stable operation, even with minor improvements. My setup is not exotic. The biggest mystery to me is what other purchasers are experiencing. I see many reviews of the item on retail outlets. So, are the people on this thread working with defective units? Or are others just lucky that they use "as-is" out of the box with no issues?
Beats me. But Netgear is the one that complaints should be directed towards, not other posters...
J
