kiddycone
Sep 07, 2026Aspirant
RAXE500 2.4 band doesn't work at all, only 5G.
I've tried changing the channels; there are no new devices or even neighborhood networks that I can tell. For devices that can use 5G, the devices use that. For ones that can't, such as the print...
- Sep 09, 2026
Factory reset worked. Everything already seemed to match the above, so not sure how that fixed it. But, all good.
kiddycone
Sep 08, 2026Aspirant
The wifi button is blinking on the printer, not the wifi. The wifi light is solid, because the network is visible on our devices, and on wifi detection app. Is there anything you can think of besides factory reset that I coudl fiddle with?
Sep 08, 2026Guru - Experienced User
So no other devices will connect to the 2.4Ghz SSID name?
Is Smart Connect disabled on the RAXE?
What firmware version is on the router?
If nothing connects, you'll need to factory reset and router and setup from scratch.
