sonofdad
Jun 26, 2026Aspirant
Wireless connect AX8 to network
My home network runs off an RS700s. I'd like to connect an old AX8 wirelessly (5Ghz), then physically connect NAS backup to the AX8 running in the garage. Just to note I'm not wanting to use the AX8 ...
sonofdad
Jun 27, 2026Aspirant
Thanks for the reply though I find it strange Netgear don't build this feature into what would still be considered a high-end home router. I'm thinking of picking up a TPlink AX1500 which is rather inexpensive and should bridge on 802.11ax
Jun 28, 2026Guru - Experienced User
sonofdad wrote:I'm thinking of picking up a TPlink AX1500 which is rather inexpensive and should bridge on 802.11ax
Per the manual, it also only has an AP mode and router mode. So it won't do what you want either.
You can find plug-in WiFi 6 extenders for about $60-$70 USD.
