dshunzeker
Sep 03, 2022Aspirant
Readycloud access either with RAXE450 or R8000 AP mode under RAXE450
I have had an R8000 for years in normal mode with readycloud access. The R8000 started having internet issues. Firmware is up to date. That is only for background. I bought an RXAE450, assuming it is a premium box and would surely have all of the same perks, like readycloud. Alas, it does not. So, the first question is if there is any plan to give readycloud access in future firmware releases for the RAXE, as this is a really useful function? Otherwise, can the old R8000 be used in AP mode under the RAXE to provide the missing functionality. I have tried a thousand ways and altered order of operation myriad other ways. Is there a port that could open on the RAXE that would do it? My setup is modem to RAXE WAN port, then RAXE LAN port to R8000 WAN port. In my last attempt, I started with the R8000 in normal operation so that I could register the USB to Readycloud. I turned off all WiFi on the R8000 to avoid interference. I am operating only from ethernet. That worked fine. I then set the device to AP mode and connected appropriately. It rebooted. It is in AP mode with the Readycloud tab showing it is registered. IP, mask, and DNS server are set to be the same regardless of mode of operation. I tried DNS set up either as gateway or directly to what my RAXE uses. I can access the drive using \\ipaddress\usb_storage. All seems like it is fine, but readycloud still cannot connect to the storage. There is something that cannot get through when the RAXE is in front. Is there just a port that I can open? Thoughts? Separately, all browsers have stopped supporting ftp, which makes that a painful alternative. I need to access my data while on travel. Help!!
Netgear doesn't share that sort of information with the people who hang out here. Older RAX devices do work with ReadyCLOUD. So who knows what may happen in future. But these features have a habit of disappearing in the pursuit of improved security.
Otherwise, can the old R8000 be used in AP mode under the RAXE to provide the missing functionality.Have you tried it? It is a simple test.
AP mode does kill various things:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But none of the USB features seem to be in there.
- dshunzekerAspirant
Thanks for the reply.
Regarding have I tried it, please see the middle of my description. In AP mode, everything works that is needed, save one item: Readycloud. I can access the drive by \\ipaddress\usb_storage\ from anywhere on the network. It is not clear if AP simply disables Readycloud or if RAXE actively blocks something. That is the question. Is there a port that can be opened or some other simple fix to get access?
Regarding, "none of the USB features seem to be in there," yes, I can make all USB functions work except ReadyCloud.
Regarding the other items on the disable list, most are obvious based on AP puts the R8000 in basically a slave mode.
Next time use paragraphs. They are easier to read than slabs of continuous text, especially when you throw in bits like "I have tried a thousand ways and altered order of operation myriad other ways".
Regarding, "none of the USB features seem to be in there," yes, I can make all USB functions work except ReadyCloud.Did you ever get the R8000 to work with ReadyCLOUD when it was running as a router?
How are you trying to access ReadyCLOUD?
There are various options, some of which cause problems for me. The Windows app, for example, is a pain whereas going through https://readycloud.netgear.com/ or th Android app is fine.
Maybe you did all that in your myriad other ways. I can't tell.
