Fixitplease02
Jun 10, 2020Initiate
Remove Netgear Armor Trial
I want to know how to delete anything associated with Netgear Armor, which somehow, it got activated for a 30 day trial. I know what it is and you couldn't pay me to use that service, much less me pay you for it, not going to happen, ever. How do I end this 30 day trial and permanently block or remove Netgear Armor? So sketchy all around ugh. Kind of makes me regret going Netgear for my Wi-Fi 6 upgrade. Thanks!
- psychopomp123Luminary
On the Nighthawk smartphone app, go to settings > security and turn off the toggle for 'enable Netgear armor'.
- Fixitplease02InitiateBut there isn't a way to just cancel the subscription and be done with it? There is nothing that I have seen anywhere to cancel or remove. Turning it off is fine but I want it gone! Lol. I paid $600 at Best Buy for that router a few months back and then suddenly I'm being hassled by a subscription service that I don't want or need, with no way to stop it.
- RajaDajaLuminaryWell,
If you have backup prior to installing Armor. Initially I didn’t install Armor after the new firmware update. But the only way to get rid of Armor other than restoring the router back to a previous point is a Factory Reset.
- RajaDajaLuminary
I found that doing a factory reset is one way to remove that Armor software. Cheapskates! We should be getting that service for free!
30 day trial! Phewy! I say.....
Fixitplease02 wrote:
I want to know how to delete anything associated with Netgear Armor, which somehow, it got activated for a 30 day trial. I know what it is and you couldn't pay me to use that service, much less me pay you for it, not going to happen, ever. How do I end this 30 day trial and permanently block or remove Netgear Armor? So sketchy all around ugh. Kind of makes me regret going Netgear for my Wi-Fi 6 upgrade. Thanks! I have the same problem. Help please
