Tarra85
Oct 10, 2023Aspirant
Router is Blocking a Favorite Website
For some reason my router is blocking one of my favorite websites (www.appagg.com) - it’s never done this before until about a couple weeks ago. I have spoken to my cell company, modem provider and bo...
Oct 10, 2023Guru - Experienced User
Should be a sticker on the ISP modem/ONT about it's model #.
Tarra85
It says Modem EN2251
- FURRYe38Oct 10, 2023Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageHas a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Might try and get a wired PC connected to the modem with out the router connected and see if the one PC can get to this web page.
- Tarra85Oct 10, 2023AspirantI have not turned it off since last update cause I got a new modem today and just activated it today so wasn’t sure if it still would need to be done. I do know that if I turn the WiFi off on my device I can go to the website just fine, it only doesn’t work if WiFi is on. And it happened after a firmware update that it started doing this. Like a couple hours later.
- plemansOct 10, 2023Guru - Experienced User
did you try a different dns?
