Tarra85
Oct 10, 2023Aspirant
Router is Blocking a Favorite Website
For some reason my router is blocking one of my favorite websites (www.appagg.com) - it’s never done this before until about a couple weeks ago. I have spoken to my cell company, modem provider and bo...
Oct 10, 2023Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Might try and get a wired PC connected to the modem with out the router connected and see if the one PC can get to this web page.
Tarra85
I have not turned it off since last update cause I got a new modem today and just activated it today so wasn’t sure if it still would need to be done. I do know that if I turn the WiFi off on my device I can go to the website just fine, it only doesn’t work if WiFi is on. And it happened after a firmware update that it started doing this. Like a couple hours later.
