amonynuts's avatar
amonynuts
Apprentice
Jan 23, 2022
Router log filled with repeated DHCP assignments
Nighthawk Router RAX45-100NAS AX4300 AX6, Firmware 1.0.5.106_2.0.70
Is there a way to disable DHCP logging without disabling logging of security events?  With lots of devices on my WiFi network getting their DHCP address reassigned every few minutes (to the same IP address they already had), my router logs quickly fill up with thousands of DHCP assignment events:  [DHCP IP: (192.168.0.x)] to MAC address ...
It would be nice if I could disable logging of the DHCP events without disabling logging of security events such as DoS attacks, RST scans, etc.  Or even better yet, maybe there's a way to increase the DHCP assignment timeout to more than 15 minutes?
  • FURRYe38's avatar
    How many devices do you have connected?
    Look under Admin/Logs for items to un-select for logging. I recommend unchecking items that your not monitoring.
    • amonynuts's avatar
      amonynuts
      Apprentice
      FURRYe38 About 50 devices.  No, I have not done a factory reset and setup from scratch since I last upgraded firmware.  Am I supposed to do that whenever the router does an Automatic Firmware Update?  I didn't see any setting specifically for disabling DHCP from the logs, but didn't want to disable logging of anything important.
