Joelbronx's avatar
Apr 18, 2023
RX50 2.4g download speed very slow
Hi All,
I have a giga blast network.  My 5gig download speed is around 800 MPS  I recently noticed that my 2.4gig is downloading only at 76 MPS  Any and all suggestions would be greatly appreciated.  We do have devices using 2.4gig but the same amount on the 5gig.  Not all device are operating so I am not sure what changed that I am getting such low downloads speeds on the 2.4 gig band?
PS:  These speeds are using WiFi, not Ethernet.
Thanks,
Joel
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What connection rates are you seeing with devices connected on 2.4Ghz.
    Is Smart Connect enabled or disabled?
    Do you have 40Mhz channel width set?
    Most 2.4Ghz devices will cap out at anywhere from 50 to 100Mpbs depending on there design and support. 2.4Ghz mostly will never see speeds near 800Mpbs. " 2.4GHz AX: 2x2 (Tx/Rx) 1024/256-QAM
    20/40MHz, up to 600Mbps" <This is a connection rate only between the router and wifi devices that support this connection rate. This differs from bandwidth speeds.
    • Joelbronx's avatar
      Joelbronx
      Tutor
      Hi Furry and thanks for your reply.  See my answers below.  Before I respond, my ,speeds have nee percent until recently  Nothing changed on my end or from the ISP.  I also worked in Broadband for years as an engineer for a major company and am baffled by this issue.
      Most recent for the RX50 and no new updates available as I checked
      I use a Netgear COX (my ISP) certified CM1100 which is connected to my Netgear RX50
      LAN cable if fine.
      Getting very good rates and even have some streaming using 2.4Ghz
      Smart connect is not enabled nor would I enable it as some of my devices cannot toggle to 5 from 2.4 and has been disabled since I have configured my set up for 3 years now
      20/40 Coexistence is enabled
      Fully agree about the Cap out rates, but previously I have gotten at least 300 Mbps.  I also know it is not the Modem as of course (stating the obvious) when I cam using ethernet the speeds are much higher for Download.  If you think of anything else please let me know.
      Thanks:  Joel
      • plemans's avatar
        I'm not sure what you're doing but I've never gotten anywhere close to 300mbps over 2.4ghz.
        max has been maybe 150mbps and that's not sustained. that's short bursts. My maximum average over 2.4ghz has been 70-100mbps. Usually less than that as I'm in an area with congested 2.4ghz signals.
