Nick121920's avatar
Nick121920
Set up one network using two AX3000 routers with five echo devices
  • plemans's avatar
    Not sure what help you're needing because you didn't put much info in here.
    You didn't give a decent description of what you're doing, whats not working, what help you need.
    You also didn't include a model number, firmware, modem/gateway info, etc.
    (hint ax3000 is a speed, not a model)
      • Nick121920's avatar
        Nick121920
        Want to set up up my two RAX40 routers to enable easy set up of echo devices.
        Currently have a new Spectrum account with a Spectrum modem (200 Mbps) wired from the road with antenna wire, then changed to ethernet for it's modem connection.  Spectrum set it up.
        Have two RAX40 WiFi Routers with separate names and passwords. One is ethernet wired to spectrum modem, then that router has an ethernet wire running to the 2nd RAX40 about 100' away.
        I understand there is a way to set up both routers on one network which will make setting up the Roku, Echo devices, smart plugs, and other devices easier in the future.  Just don't know how to do it.
        I have not changed the IP addresses on the RAX40 routers from the factory settings.  I am using the RAX40 names and passwords that came with them.
        I'm thinking that if I have both routers set up on the same network, I will have to make each router have the same network name (SSID)(keep different passwords for them); and change the IP address on one of them designating it as secondary.
        Is that correct, and if so - how do I do it?  I would appreciate any help I can get.  Thanks...
