gbridgeman's avatar
gbridgeman
Follower
Dec 30, 2019
setup of nighthawk ac1900 behind Att uverse router
My router provided  by ATT has too many devices attached so I bought the Nighthawk since users said is can go behind the primary ATT router.
I cannot connect to the new router. There are no directions with the router so I'm stuck.
Thanks
1 Reply
  • plemans's avatar
    A couple things.
    1. you put nighthawk router but your signature lists the C7100v which is cable modem/router.
    2. You put that you have att with a att router. running 2 routers on a network puts you in a double nat. You can get around this by placing the att in pass through/modem only or a regular router in AP (access point mode). But that option isn't availble if you have the C7100V.
    https://kb.netgear.com/30186/What-is-Double-NAT
    So what actual router did you buy?
    You can go to netgear.com/support/   type in your actual model number and it has install videos, install instructions, manuals, and firmware.
