DudeRides
Mar 20, 2020Aspirant
Should I Try To Block These IP's?
Hello,
With two people now working from home, I have noticed some unusual behaviors/slowdowns in browser response. I'm just learning the basics as far as diagnosing what might be improved and looked into the log on board my AX12. It shows a lot of "DoS Attack: ARP Attack" and "DoS Attack: TCP/UDP Echo" and "DoS Attack: SYN/ACK Scan". I can see the IP addresses associated with these attacks. I'm trying to figure out if these attacks might be the reasons for the change in performance/behavior on my browser and what to do to protect against/reduce/prevent them.
Is the first/basic step to block the source IP's?
If so, how do I do that?
Thank you,
Dude
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
Here is a useful tool for that task:
IPNetInfo: Retrieve IP Address Information from WHOIS servers
Not if you want to use those sites.
- DudeRidesAspirant
Interesting. I parsed through most of the log from Thursday/Friday and indeed most of the IP addresses were from Charter, but there were a few from China and Indonesia.
Rather than blocking IP addresses, should I look for Ports to block?
