mnasiff's avatar
mnasiff
Slow Speed Nighthawk
I have an optical connection of 900 mb but by wifi I only get 340 mb connected to the 5G signal with only 1 device connected
my router is the Nighthawk RAXE290 tri-band
Anyone know what might be happening?
Thank you
  • plemans's avatar
    What device are you testing on?
    What firmware is on the router?
    HOw are you testing? What site/app/ etc?
    • mnasiff's avatar
      mnasiff
      Thanks for your answer.
      I have tried (one at a time) with an iphone 13, a macbook pro, a macbook air all new from the latest generation.
      The firmware is: V1.0.7.62_1
      I have tested with fast.com and speedtest.net
      The router indicates that it receives 600 MB upload and 900 download from the modem, this is correct, it is what I have contracted, if I connect by cable, I do receive 900/600, but as I said in my post none of my devices connected by wifi reaches more than 340 mb. I also tried with an eero router and exactly the same thing happens.
      • plemans's avatar
        so if both the router from netgear and Eero are hitting the same speed, it makes me thing its the devices that are the bottleneck.
