Nucarojl's avatar
Nucarojl
Follower
Sep 27, 2022
Smart TV (Samsung) buffering problem
I've got a
Nighthawk AX12
12-Stream AX6000 WiFi Router
Model RAX120
Settings from my phone app when checking various devices tell me that the Smart TV is connected with the 5G speed. However, when I first go to any particular channel, there's a buffering that takes place intermittently about 4 or 5 times before things setting down and it stops. If I change channels the problem repeats. This is all done via a wi-fi connection, and firmware is updated. I'm using all Apple OS on iPhone and other devices.
Any suggestions?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Which Smart TV? Most models that have cropped up here are limited to 2.4 GHz. That is fast enough for most uses and is often better than 5 GHz which has a shorter range.
    One solution to smart devices is to use an Ethernet connection, most Samsung TVs have that feature. No need to run a cable. You can use Powerline Ethernet to turn your mains circuit onto an Ethernet link.
