Snowdawg
Dec 17, 2022Initiate
Sonos speakers unable to connect
I've been running my Sonos system on a Nighthawk RAX43 for 2 years with no problems. However, this week it decided to stop working. Sonos support suggests that I need to login to the router configura...
michaelkenward
Dec 18, 2022Guru - Experienced User
Snowdawg wrote:
Sonos support suggests that I need to login to the router configuration screen via a web browser but I am unable to do that.
Unable in what way? You don't know how to do it? You try and it doesn't work?
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
and this:
If you cannot login to your router | Answer | NETGEAR Support
The router is blocking speakers but I have no way to correct that. Any ideas?
Blocking how?
There may be some clues here:
Search - NETGEAR Communities – sonos
Snowdawg
Dec 26, 2022Initiate
Typically, I can access the router configuration by typing the IP Address into a browser window. However, this was not working for me for some reason when I posted this message. It is working now, however. Thanks!
- michaelkenwardDec 26, 2022Guru - Experienced User
Did you reboot anything? I find that media toys need this from time to time.
