joy5toys's avatar
joy5toys
Speed Test
Our community has gotten fiber service and got 1 Gbps service with our ISP.
I'm using:
NETGEAR Nighthawk AX8 WiFi
8-Stream AX5700 WiFi Router
with latest firmware available.
The concern I have is with PS4 connectivity performance.  The speed I get on the Ps4 is around 490 Mbps download and 110 Mbps download wired directly to the router using a CAT8 cable.
Running the speed test on the router itself gives me on the average:
Download: 550 Mbps
Upload: 530 Mbps
That's not close to the 1 Gbps expected.
I have run speed tests directly to a laptop and results I got:
Download:  > 900 Mbps
Upload: > 500 Mbps
Is there an issue with the router for the speed performance?  Any tools should I use to troubleshoot the issues?
Your hep is very much appreciated.
Thanks.
  • FURRYe38's avatar
    RAX###?
    What are your wired speed results with a wired PC connected to the ISP modem? Same at the router?
    Use Ooklas installable speed test app on the wired PC.
    • joy5toys's avatar
      joy5toys
      RAX75
      Firmware: V1.0.6.138
      ONT Manufacturer: Nokia
      Model: unknown, S/N available externally
      Factory reset has not been done.  Kindly, provide resource for performing factory reset if recommended
      As I have shared in my original post:
      Wired PC to ONT connection speed test: > 900 Mbps download & > 500 Mbps upload
      Router speed test:  Download: around 550 Mbps & Upload: around 500 Mbps
