FiddleFart's avatar
FiddleFart
static line
Im having problems with my camera's
What's happenning is the camera's will work for a bit, then won't work at all, then after a day or two, they will work then back off.
Is it possible to have one wired line (to camera's) set up for static (so it wont keep changing the IP address?)
Router - AX1800/RAX10
Cameras - Hiseeu ADR-8
If so, how will I do it?
Thanks in advance
  • FURRYe38's avatar
     You can set IP Address Reservations on the router for connected devices.
    • FiddleFart's avatar
      FiddleFart
      Ive did set the cameras to a permant address.
      Ive done that but it sends the cameras to the
      "view list of allowed devices but not connected to the network"
      Ive checked all of the connections between the nvr and router.
      Ive reset my router.
      Ive reset the nvr.
      • FURRYe38's avatar
        Can you use the Choose File button and attach a screen shot of what your seeing on the router?
        What browser are you using?
