stanfrench's avatar
stanfrench
Luminary
May 15, 2022
Time Machine does not recognize USB drives connected to RAX200
I have been using the Nighthawk RAX200 router for slightly more than a year now. I had attached a Western Digital 2TB USB drive to the USB port of the RAX200 for use in Time Machine back ups to my iMac and Macbook Pro. It worked fine until the end of April, but now Time Machine cannot recognize that any router-attached USB drive exists.
I am still able to access the router-attached USB drives via Finder, but Time Machine cannot. Also, Time Machine will recognize the USB drive when I attach them directly to the iMac or Macbook, but not when they are attached to the RAX200. This only started happening after the end of April.
Has anyone else faced this problem? Any suggestions for troubleshooting? Thank you.
  • plemans's avatar
    What firmware version are you on? there was a change around that time.
    did you try a factory reset or downgrading the firmware?
    • stanfrench's avatar
      stanfrench
      Luminary
      The firmware I'm running is V1.0.6.138_1.0.76. I haven't tried a factory reset or firmware downgrade yet as I'm in the beginning stages of troubleshooting.
        stanfrench
        Luminary
        FYI, the former path that was recognized by Time Machine was: "afp://RAX200._afpovertcp._tcp.local"
        This no longer works. I tried "smb://readyshare" which allows the USB drives to be recognized by Finder, but Time Machine does not.
        Is there another path name that would allow Time Machine to be recognized? Any other settings I can adjust in the router? I really don't want to reset or downgrade the firmware unless I can be assured that it works.
