Corneileous
Jun 28, 2025Aspirant
Using RAX41 router in normal mode while connected to my ISP-provided router
Right now its in AP mode as advised via Netgear tech support back when I could get support for it and not being charged but since it is in AP mode, there's a lot of settings I can't access because of...
CrimpOn
Jun 29, 2025Guru - Experienced User
The general advice is to have "one router" because connecting one router to another router leads to what is often referred to as a "Double NAT" . Double NAT can interfere with a number of specific applications, including certain forms of internet gaming, sharing files on the internet, and connecting to the local network from the internet. (internet search for more information and examples)
Having only one router also means that every device in the home is part of one local network. Every device can communicate with every other device. For many users, this is not particularly important.
Because of the design of 2.4G WiFi, creating 2.4G networks that are at least five channels apart does allow support for more 2.4G devices. (This is not a trivial subject, as WiFi is impacted by other WiFi systems in the neighborhood, so quantifying the benefit of having both systems active on 2.4G WiFi is pretty complicated.)
Having multiple 5G WiFi networks is a bit different, because although 5G WiFi uses one channel for management purposes, actual data communication tries to create packets that use the entire 80 or 160MHz bandwidth.
So, while the general advice is to disable WiFi on the ISP router and use only the user router for WiFi (in AP or Router mode), the subject is highly technical.
If there are setting or capabilities of the RAX41 that are important to you and a Double NAT will not cause any problems, then there is nothing wrong with putting the RAX41 in Router mode.
- CorneileousJun 30, 2025Aspirant
So please excuse my confusion but when you talk about this double NAT stuff, is that only possible for if I was to return my Netgear router back to normal router mode while having it plugged into my ISP provided router or are you saying this is something that’s always been a possibility while having this router configured into AP mode?
I guess I’m just a little naïve as to what could’ve really been going on this whole time but for quite some time now, I’ve had both routers in use like I described in my opening post and as far as I know, there was never really any problem. Even when my stepson lived there and being that the ISP router was in his bedroom, he always had his fancy homemade gaming computer plugged into that router via ethernet and I don’t remember him ever saying there’s any issues with all the gaming that he did.
But so in conclusion, am I just better off leaving it all how it is? I mean, is that why the Netgear tech-support person I talked to instructed me to do this in AP mode? Also, are there really any settings that I really need to have access to for better performance? Like, in other words, is there really any kind of advantage returning my Netgear router back to router mode then just leaving it where it is? If I understand correctly, if I put my router back into normal router mode, that means I’m gonna have to manually reassign the IP addresses, correct?
