Dan1000
May 08, 2021Aspirant
Using RAX45 Router with EX6120 range extender
I have a model RAX45 wifi router that I have located next to a fireplace. (RAX45 firmware: 1.0.2.82)
Most convenient location due to ethernet connections with windows 10 computers. The fireplace degrades the wifi signal to a portion of my house, so I purchased a Netgear EX6120 wifi extender (EX6120 firmware: v1.0.0.54.1.0.34).
I detatched the two side antennas from the RAX45 router and extended them about six feet away from the router with coax cables. I was able to get a signal to the extender I placed upstairs, but the extender's instructions say to place it where the router link and device link LED lights show green or amber. Sometimes these device LEDs will show amber or red. The extender provides a good signal most of the time, but it is occasionally weak.
My question is about extending the RAX45's antenna with cables. The antennas are marked with "rear" and "side." Are all the antenna's working with both the 2.4 and 5 ghz bands? If I extend the back antennas with cables, do I need to place the extended antennas in any particular configuration? That is, should they be roughly similar to the placement when the antennas are attached to the router? Second question: Is the fact that the device and link LED sometimes show amber or red caused by different amounts of data traffic on the different bands, either from devices in my more or the wifi from my close neighbors wifi?
Sort By
extending the antennas seems like a great way to attenuate the signal.
Why not use a longer ethernet cord and simply move the whole router?
- Dan1000Aspirant
Thanks for the reply. That's an option, but I have five devices wired to the router in close proximity. The router is also right next to the cable connection that feeds my cable modem. I'm in investigating alternatives that don't require running cables farther from the cable modem location.
Any other locations you can move the router/modem to?
Again, adding extensions to an antenna is only going to reduce its signal
