sanmeet's avatar
sanmeet
Guide
Mar 25, 2021
usually Cant access 192.168.1.1 plus readyshare unaccessible
issue 1:
I have RAX80 with latest firmware. Im rarely able to connect to 192.168.1.1. Im using windows 10 pro laptop and connected via wifi to RAX80
Even connecting via android app shows Rax80 disconnected 9 times in 10. Im connected to internet just fine via the router. Ping 192.168.1.1 works fine
Issue 2:
I have two usb drives connected to the two usb ports of router one 4TB with external power, another 2TB portable one. Router page shows both drives connected but Im neither able to access any via \\readyshare locally. Also when i try to access via ReadyCloud..I see RAX80, when I double click it, it shows "No volumes or USB disks"
What am I doing wrong?
  • sanmeetclicksud wrote:
    issue 1:
    Issue 2:
    This will be helpful for you..?
    https://community.netgear.com/t5/Nighthawk-WiFi-Routers/ALL-Netgear-USB-Drive-Mapping-Issues-ReadyShareConnect-exe/m-p/1311880%22%3ESolved
  • > usually Cant access 192.168.1.1 [...]
       "usually"?  What happens when you try?  (Note: "cant" is a word,
    different from "can't".)  "can't" is not a useful problem description.
    It does not say what you did.  It does not say what happened when you
    did it.  As usual, showing actual actions (commands) with their actual
    results (error messages, LED indicators, ...) can be more helpful than
    vague descriptions or interpretations.
    > I have RAX80 with latest firmware. [...]
       As always, an actual version number would be more useful than your
    opinion of what's "latest" today.
    • sanmeet's avatar
      sanmeet
      Guide
      OP> OK Boss ...I can't :-)
      What I did?..I typed 192.168.1.1. in address bar...of Chrome and pressed enter
      then I waited and then waited some more..until chrome told me "This site can't be reached"  Yes, there was an apostrophe in the can't Chrome used. The laptop is with windows 10 pro. Same thing happened with another laptop...The app on my android also couldnt connect to router
      BTW, I restarted the router and it did connect. I had this issue earlier too, until I did a factory reset and was finally able to get the router login. Are people experiencing routers mood swings too??
      OP>
      My Router: Nighthawk RAX80
      Firmware Version V1.0.3.106_1.0.50
      • sanmeet's avatar
        sanmeet
        Guide
        So as I mentioned above, I was able to log in router after a restart. I still did a factory reset. in the hope of solving readyshare HDD access possible but Im able to access the USB HDD 4TB connected to router USB via ReadyCLOUD but not locally via laptop connected on the router's wifi.
        The router gave me address "\\readyshare\USB_Storage" which put in run and pressed enter. I got Network error "Windows cannot access \\readyshare\USB_Storage"
        How do I solve this...Any help would be appreciated...TIA!
