ByteBiter's avatar
ByteBiter
Follower
Sep 20, 2024
Vivaldi browser not syncing over LAN but can sync over WIFI
Hardware: RAX200
Firmware: V1.0.10.140_1.0.79
I use the Vivaldi browser, which syncs its settings across computers. I have been running into the following issue.
I have multiple computers connected to the same Nighthawk router. Syncing fails on the one computer connected using LAN. The computers that use WIFI have no problem.
I can confirm that the router is the problem, as plugging the problematic computer into the network directly allows my browser to sync its settings.
Is there a router setting (specific to LAN) that might prevent some processes from reaching the web while the same services would run OK when connected to WIFI (on the same router)?
  • FURRYe38's avatar
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    Has a factory reset and setup from scratch been performed?
  • plemans's avatar
    might check on that pc if you have any security, vpn, or ethernet settings.
    Have you tried the other devices wired?
    Or have that pc set with a public address and not private when on ethernet? (check in your windows settings)
