Hyperflasch's avatar
Hyperflasch
Follower
Mar 08, 2020
WAN Aggregation Rax120 and Fritzbox
Is there a possibility to bundle 2 Ports of the Fritzbox to get higher Bandwith ? The Ports of the Fritzbox are just 1 GB and i want faster connections by wire, cause my PC and AX got 2,5, GB Ports. The AX120 got the menu Point for aggregation and i placed in 1 Cable in WAN and 1 Cable at Port 1... both from Fritzbox but there is an error comming from AX. I can also not find any option for wan in Fritz overlay.
Can anybody help me ? Im really not that common in this technical things.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
1 Reply
  • which fritzbox do you have? Thats the key as if it doesn't have wan/lan aggregation, then you can't do what you're trying to do  .
