Retired_Member
Sep 08, 2019WAN and LAN LAG at the same time
I have the RAX120 and have a NAS that I am using LAG on LAN ports 1 and 2. This is working great but would like to know if I can use WAS LAG as well. I know there is the WAN port and the 2.5Gb port...
- Sep 12, 2019
shamelin73 - The RAX120 currently does not support WAN & LAN aggregate at the same time.
~Christian
Retired_Member
Sep 10, 2019Is there any clear information on this? Or a diagram showing the connections.
I know like the other brand with an A uses the WAN and LAN port 4 for WAN LAG and LAN ports 1 and 2 for LAN LAG.
The wording on the RAX 120 is a bit vague.
Christian_R
Sep 12, 2019NETGEAR Employee Retired
~Christian
- Retired_MemberSep 12, 2019
I am supprised that this is not supported. The AX8 does and other brand AX routers do. Could it be that this would be a future add via the firmware?
- Christian_RSep 13, 2019NETGEAR Employee Retired
shamelin73 - If you'd like to to see this feature added via firmware, we recommend posting this idea on our idea exchange board.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
~Christian
