smarbut
Oct 17, 2025Follower
Web browser into local router then and only then do I get the personal questions
Interestingly I can login RAXE500 through the cloud, and the mobile app, yet when I try through a web browser into local router then and only then do I get the personal questions. I am confident, tha...
Oct 17, 2025Guru - Experienced User
smarbut wrote:Interestingly I can login RAXE500 through the cloud
Great, so you do have access.
smarbut wrote:when I try through a web browser into local router
You need to log in as "admin" when you do this (and can't use your cloud credentials). Are you doing that?
Also, are you using the steps here to reset the admin password?
- https://kb.netgear.com/24220/How-to-reset-your-NETGEAR-router-admin-password
FYI, I redacted your personal info from your post. It is best not to include a direct email contact in a public forum.
