NightHawkRAX80
Jul 30, 2020Aspirant
What does it mean if my WPS LED is flashing white and never stops?
According to the manual: The WPS LED blinks white during the WPS process and then lights solid white when the WPS-enabled device connects to your router's WiFi network. I can not seem to get it ...
Jul 31, 2020Guru - Experienced User
You're not the first with this issue:
some were able to reset it with a simple factory reset and reinstall.
