Dhiren2005
Jul 30, 2020Follower
What is OFDMA
What is OFDMA???? Does it Reduce speed or increase it. And how to increase range and speed in the Router. What is the Best routers ip setting
Thank you in Advance
1 Reply
Dhiren2005 wrote:
What is OFDMA????https://kb.netgear.com/000059685/What-is-Orthogonal-Frequency-Division-Multiple-Access
Dhiren2005 wrote:
Does it Reduce speed or increase it.OFDMA (and UL-/DL-MU-MIMO) is made to enhace the concurrent usage of wireless devices with different capabilities.
Dhiren2005 wrote:
And how to increase range and speed in the Router.Range is given by the power "on air" (resricted by regulations) and the sensibility of the receivers.
Wi-Fi 6 is the first standard not designed for more speed - much more for multi-user/multi-device access.
Dhiren2005 wrote:
What is the Best routers ip settingWhat do you want to know?
