mohcse's avatar
mohcse
When L2TP login fails, revert to non-login connection, how ?
Hi, I have Rax40v2 router. My internet connection doesn't need login. However, I need the router to always connect to an external L2TP vpn account, so I changed the internet connection type to L2TP...
  • plemans's avatar
    Aug 22, 2022
    You can't.
    You have it set for the internet connection to come from your VPN directly.
    It doesn't have a failover option with that router.
    Its the downfall of setting up going through a vpn that route.
