peabody
Oct 06, 2021Follower
Where's the Firewall?
I just bought this router and got it setup, and I wanted to create a firewall rule (specifically to block all IP addresses in China), but search as I might, all I can find is how to do a stateful keyword filter or to close specific ports.
Where are the basic firewall rules?
Can I not deny any connections from a specific IP or a range of IP addresses?
Note: I have the RAX70, which doesn't appear in the Community Model list.
1 Reply
- DarrenMSr. NETGEAR Moderator
There is no advanced firewall settings that can be adjusted by the user on the router. If you are looking for more router protection I suggest taking a look at Netgear Armor. https://www.netgear.com/home/services/armor/
DarrenM
