Peter_lgy
Aug 08, 2019Aspirant
Why i can't disable the implicit beamforming on RAX120?
In the advance wireless configuration area of RAX120 , I can only enable or disable mu-mimo ..However for RAX80, I can enable or disable implicit beamforming .
What does that mean?
On RAX120 ,the implicit beamforming have been canceled or must be enabled?
Who can tell me?
Thanks a lot?
- Peter_lgyAspirant
- Christian_RNETGEAR Employee Retired
Hello Peter_Igy - Thanks for your post and a screenshot. You can find more information about Implicit Beamforming in the article linked below. Would you also mind providing the firmware version the RAX120 is currently on.
Thanks,
Christian
- Peter_lgyAspirant
Thanks Christian!
I have read the article you told me. Yes, other routers can disalbe the implicit beamforming such as RAX80. There do exist the check box. However on RAX120 NO.
So i am puzzled if RAX120 doesn't support implicit beamforming or just won't let the customers change the function? Can you tell me? Thanks a lot!
The firmware i have updated to v1.0.1.90.
