GTI's avatar
GTI
Wi-Fi 6
I have a Nighthawk AC1900 with voice router. What is the equivalent model that isWi-Fi 6 compatible?
  • plemans's avatar
    AC1900 is a speed, not a model.
    what actual model do you have?
    What are you trying to do? If you're upgrading to an AX device, you have lots of potential from staying at the same basics to increasing the speeds all the way to triband or mesh. Are you wanting the same basic thing or wanting an upgrade (whole point of going AX)
    • GTI's avatar
      GTI
      C7100B is the model number. Want eliminate dead spots. Faster WiFi would be better with wifi6? I’d Xfinity’s hardware better than what is available to buy?
      • GTI's avatar
        GTI
        My Gateway is a Netgear C7100V, correction.
