Timbree's avatar
Timbree
Follower
Nov 28, 2019
Wi fi wont connect on setup
All of my lights are green except for the one that I believe is wifi and it is amber colored what do I do.
1 Reply
  • plemans's avatar
    You say wifi won't connect.
    Did you set it up?
    do devices that are hardwired into the router work?
    Have you tried logging into the router to change/setup the wifi ssid/password?
    Is it all devices or just one?
    "All of my lights are green except for the one that I believe is wifi and it is amber colored what do I do."
    You "believe its wifi" and its amber? here's the link to the support site with firmware, troubleshooting, and a manual that walks you through the led's and what it means for color/blinking.  I'd take a look through it so we can better understand what light it is and the issues.
    https://www.netgear.com/support/product/rax40
