alexxx55555
Oct 20, 2020Aspirant
Wifi 6 is not working
Hi all,
I have RAX40 router with WIFI 6 i have WIIF 6 wifi card.
I conncted to my router but i dont have network using wifi 6 and unable ping to ther router.
If i change the protocol to WFI AC i able to use the network and to ping to the router
Can someone to help?
Which wifi 6 card is it?
Reason i ask is many manufacturer's card were having issues seeing wifi 6 when they were first released. check with wifi 6 card it is. then go directly to that device manufacturer's website and find the driver for it. Install that driver.
So if you have a sony laptop with an intel chip in it, get the driver directly from intel. don't use windows update or the sony website.
- alexxx55555Aspirant
Hi,
My network card in Intel wifi 6 ax 200 160MHZ
i install the lates driver
and the computer can connect to WIFI 6 protocol but unable to connect to internet
any idea?
