margiweno
Sep 16, 2023Follower
Wifi 6 on main router but using a wifi 5 as an access point
I've been researching about this and can't find a straight answer. I have my main router, a NETGEAR Nighthawk AX5 RAX43 and it works great except in two spots in my house, thankfully the house has et...
michaelkenward
Sep 16, 2023Guru - Experienced User
margiweno wrote:
Can Iset it up as an access point so my devices seamlessly connect to it when moving along, will having one SSID working on wifi 6 and wifi 5 be an issue?
Depends what you mean by seamlessly. You can give them the same login details but these won't be Mesh systems so they will not cooperate in handing over client from one wifi source to the next.
