Th3Alchemist
Jun 08, 2020Aspirant
WiFi connection Unstable
I just got this new Router. Freshly installed and upgrade to the latest firmware (Firmwareversion V1.0.3.80_1.0.1). I've manually chosen a wireless channel that wouldn't interfere with the one if my neighbours. Problem is I keep losing connection on wireless. Rapidly disconnecting-reconnecting. Happens on all wifi devices.
This is the only hint I get from the log:
[DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 14:05:10 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 14:03:57 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 14:02:59 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 14:01:59 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 14:00:58 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:59:49 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:58:05 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:48:01 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:45:59 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:45:05 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:44:03 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:43:04 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:42:05 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:41:06 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:40:09 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:39:06 [DHCP IP: 10.0.0.5] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:38:52 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:38:11 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:37:16 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:36:23 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:34:22 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:34:04 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:30:12 [DHCP IP: 10.0.0.6] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:29:17 [DHCP IP: 10.0.0.7] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:29:01 [DHCP IP: 10.0.0.6] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:28:24 [DHCP IP: 10.0.0.6] to MAC address <hidden mac address>, Mon,Jun 08,2020 13:28:06
It's impossible to have a stable line. What can I do? Wired connection are stable.
- ScottishTutor
Long shot but is your dhcp lease time 60 secs?
- ScottishTutor
Pressed the wrong button.
also see two ips there are the MACs the same across all those logs ?
- Th3AlchemistAspirant
Couldn't find the DHCP lease time. Also those MAC Addresses are different.
Wireless Setup:
- AX Enabled
- Smart Connect Enabled
- 20/40 MHz Coexistence Disabled (Default)
2.4GHz:
- Channel set manually
- Mode: Up to 600 Mbps (Max)
- Transmit Power: 100%
5Ghz
- Mode: 2400 (Max)
- Transmit: 100%
Both WPA2-Personal[AES]
LAN Setup:
- IP Address: 10.0.0.1
- IP Subnet: 255.255.255.0
- RIP Direction: Both (Default)
- RIP Version: Disabled (Default)
- Using Router as DHCP Sever (10.0.0.2 - 10.0.0.254)
- No Address Reservation
QoS Enabled (But also works terrible)
