greg10e's avatar
greg10e
Follower
Jun 20, 2025
Wifi disconnects once a week
I have the same problem. couple of years now, I guess
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have joined in on an existing conversation that may or may not have anything to do with your problems.
    There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
    If you do want help with your problem, check previous stuff that may be related then start your own discussion.
    If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
