Stoop411
Jan 06, 2019Aspirant
Wifi speeds much slower with new AX6000 router
We have had Comcast come out to check our connections and they are good. When I use the night hawk app and test my internet Connection I'm getting around 471 down and 23 up speeds. When I do a speed t...
microchip8
Jan 06, 2019Master
AX6000 is a speed indicator, not a model number. That would be AX8 and AX12. Which one do you have?
Also do you have AX turned on? If so, I suggest turning it off
- Stoop411Jan 07, 2019AspirantI have the AX8
- DarrenMMar 06, 2019Sr. NETGEAR Moderator
Have you tried to adjust the wireless channel on the router?
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
- E999Apr 26, 2019Guide
Had this same problem. After 2 weeks of trying, just fixed it. Although my computer is less then a year old and I update my drivers frequently, this had to be updated this way.
Click on network and internet settings. Next click change adaptar options.
Now, right click on your wireless adaptar and click properties.Click confligure, then click driver.
Now click on update driver.
I have updated this driver manually in the past, but for some reason it needed to be updated this way.
I have followed the instructions on all these sites regarding this problem and I feel, based on my experience, this is the solution to most of them.
Please post back so I know if this correct.
Good Luck!
If it works, please post.
