Stoop411
Jan 06, 2019Aspirant
Wifi speeds much slower with new AX6000 router
We have had Comcast come out to check our connections and they are good. When I use the night hawk app and test my internet Connection I'm getting around 471 down and 23 up speeds. When I do a speed t...
Stoop411
Jan 07, 2019Aspirant
I have the AX8
DarrenM
Mar 06, 2019Sr. NETGEAR Moderator
Have you tried to adjust the wireless channel on the router?
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
- E999Apr 26, 2019Guide
Had this same problem. After 2 weeks of trying, just fixed it. Although my computer is less then a year old and I update my drivers frequently, this had to be updated this way.
Click on network and internet settings. Next click change adaptar options.
Now, right click on your wireless adaptar and click properties.Click confligure, then click driver.
Now click on update driver.
I have updated this driver manually in the past, but for some reason it needed to be updated this way.
I have followed the instructions on all these sites regarding this problem and I feel, based on my experience, this is the solution to most of them.
Please post back so I know if this correct.
Good Luck!
If it works, please post.
- schumakuApr 26, 2019Guru - Experienced User
E999 That's well possible. What kind of wireless adapter are you talking of here, make, model, ... and which driver version?
Qualcomm QCA61x4A 802.11ac Wireless Adapter.
I updated the software on the dell website which didn't seem to work. Then, when I update the driver the way mentioned above it fixed it.
