jvhaslup's avatar
Sep 30, 2020
Wifi6 Nighthawk Firmware update keeps failing
Hi all!
Tried updating the available firmware update last night, and it failed multiple times.
Looking for a solution that doesn't include resetting my router to factory defaults.
R,
Jim
  • I wouldn't use the app. Its where we see the most issues with corrupt firmware. I'd recommen doing it over a hardwired connection.
  • plemans's avatar
    are you updating using the automatic update feature?
    Or are you trying to manually update it? (I'd recommend doing it manually and doing it over a hardwired connection)
      • plemans's avatar
