sgau's avatar
sgau
Tutor
Jan 13, 2022
will orbi 6E work with nighthawk AX12?
will orbi 6E work with nighthawk AX12 Wifi Router?
1 Reply
  • FURRYe38's avatar
    As far as?
    Depends, What are you using for your host router? Orbi or RAX?
    Orbi has both 5 adn 6Ghz frequencies where the RAX only as 5Ghz.
    If you set up the RAX as a client in bridge mode it will connect to the Orbi system, just only connect on 5Ghz.
    The RAX will not integrate into the Orbi MESH system.
