jwallace2121's avatar
jwallace2121
Wireless Access Point & Ethernet Hub At Same Time?
I recently purchased and quickly set up a new AX2400 Nighthawk as a wireless access point successfully.  Able to connect devices wirelessly but unable to access the internet from devices connected to the ethernet ports (1-4).  In the admin console, I can see the hard-wired connections, but the respective devices cannot connect to the network via 'ethernet'  in settings.  I bet that I am missing something fundamental, any help is appreciated.
Hardware Version: RAX30
Firmware Version: V1.0.10.94_3
Operation Mode: Access Point
  • jwallace2121's avatar
    jwallace2121
    Jun 13, 2024
    Problems resolved!  Unfortunately, we are not sure how but the next morning our (1) PC was able to connect to the Nighthawk AP both wirelessly and via ethernet.  Guessing that our ISP router or some other setting took several hours to resolve.  For the (2) laptop, we identified that a recently purchased USB-c to ethernet adapter doesn't work with our setup, but swapping it with another enabled the laptop to connect wirelessly or via ethernet.
      jwallace2121
