sonofdad
Jun 26, 2026Aspirant
Wireless connect AX8 to network
My home network runs off an RS700s. I'd like to connect an old AX8 wirelessly (5Ghz), then physically connect NAS backup to the AX8 running in the garage. Just to note I'm not wanting to use the AX8 as a wireless extender, I only want Wi-Fi connection to the RS700s.
I'v gone through a few tutorials online most of which recommend the Wi-Fi setup of the two routers match exactly; name, channel, security. When I do this my devices such as Google Nest all decide to connect onto the AX8 which has no internet connectivity. Also if I change the AX8's IP I can't connect to it for some reason?
Can someone please help
Actually that is the mode you need (even though you don't care about the AX8 wifi client network).
Unfortunately the AX8 doesn't have that mode. Both the AP mode and Router mode require an ethernet connection to the RS700.
You need one of these options:
- an extender with ethernet out
- a wifi adapter with ethernet out
- a powerline networking kit (if the garage uses the same breaker box as the main house).
- run an ethernet cable to the NAS
The extender is probably better than a wifi adapter if you are connecting to the NAS - easier to manage it from your phone, since you can connect to it over wifi.
- sonofdadAspirant
Thanks for the reply though I find it strange Netgear don't build this feature into what would still be considered a high-end home router. I'm thinking of picking up a TPlink AX1500 which is rather inexpensive and should bridge on 802.11ax
Per the manual, it also only has an AP mode and router mode. So it won't do what you want either.
You can find plug-in WiFi 6 extenders for about $60-$70 USD.
