JudyGrantham
Feb 04, 2022Follower
X7500 lites
Should blue lite glow when 5g is establishef
You gave us nothing to go off. X7500 is not a valid NG model.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with. - plemansGuru - Experienced User
what actual device do you have?
