mugfors's avatar
mugfors
Tutor
Mar 03, 2023
C7000V2 Parental Controls Options
I was wondering why there are no options for parental controls in the Nighthawk app. I had a Netgear router that had Circle and I found it helpful for keeping my kids off the internet when I needed it...
  • plemans's avatar
    Mar 04, 2023
    Might be able to set up a pihole on it and do some site blacklisting. theres quite a few ready-made for parental controls/site blocking.
    I've done that before.
    when the little monsters get older, they'll figure out ways around it but works fine for younger ages. 🙂
