FURRYe38's avatar
New - RBK752/753 Firmware Version 4.6.3.7 with SPC
For all you Orbi AX 7 series users, Smart Parental Controls are now available:
https://community.netgear.com/t5/Orbi-AX/New-RBK752-753-Firmware-Version-4-6-3-7-Released/m-p/2115667/highlight/true#M17008
Please post about any SPC issues, support, help or information here in this forum.
Good Luck.
  • sharmy's avatar
    sharmy
    Jul 14, 2021
    Confirming successful access to SPC via the app.
    Per Christian_R's instructions, I had to remove and reinstall the app for Parental settings to become visible.
    Christian_R wrote:
    Hello Community!
    I've linked an article below on how to setup/install NETGEAR Smart Parental Controls. Feel free to let me know if you have any questions! If you're unable to see the option in the Orbi app, may you reinstall the Orbi app and let me know if your issue persists.
  • Great to see this has finally been added.
    Now for the important stuff... how does one access these settings? I must be missing something!
    • FURRYe38's avatar
      Did you install the FW and reset and setup from scratch?
      I haven't seen the UI as i don't have the 7 series Orbi.
      Look under the Basic Tab for Parental Controls menu option?
      Or Try under Advanced Tab/Security?
      There maybe a Upgrade to Netgear SPC button seen here?
      • sharmy's avatar
        sharmy
        Apprentice
        Yes - set up from scratch.
        No options in the UI and nothing in the app.
