2dogs81's avatar
2dogs81
Nintendo Switch wont connect to internet but can connect to my router.
I have a AX6000 orbi system.
When I first set the system up several months ago, all my devices, except an older samsung tv connected without a hitch.
Recently I used the parental controls in the orbi app to pause my sons internet connection on his switch.
When I unpaused it,  the switch no longer connects to the internet.
I have been able to hotspot from my phone as long as it's not on the wifi successfully, as well as turning the old wifi network on from my ISP to verify that the switch can work.
I did leave my old ISP wifi on for a couple of days as I couldn't figure ot out and that has caused issues with performance of my orbi system so want to get this sorted asap.
I have a ISP modem router that provides a landline and 5g internet redundancy for outages causing me to leave in place and plug the orbi into this as the wifi.
The orbi app and switch shows the device connected to the orbi system, just unable to reach the internet.
I've tried manually setting up the configuration on the switch but that's not working at all.
Not sure why it's gone from working well to no longer working well just because I pressed pause on the connect.
I have reset the orbi and the switch a number of times also to no joy.
Thanks in advance
1 Reply
  • FURRYe38's avatar
    What mobile platform are you using for the Orbi app?
    What version of Orbi app are you using?
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
    New: https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
    https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
    https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2 first...
